You can play with the column lengths by entering the elevation and top elevation values as in the attached picture. If you enter + values to the value of Top level, the column length will increase as much as the value you entered from the floor ceiling, if you give a negative value, it will shorten. Similarly, the + and - values that give to the elevation value will bring the column foot down and up from the floor of the floor.
