HELLO, column shear force is not provided in the attached project, how can I fix it?
Log in or register now.
Hello, In the project, the superstructure is interactively solved. There is no interaction because the foundations TK1-2-3 are not in line with the panels. Also, the TK8 foundation BAP01 panel It is not connected to both nodes.If the basic data entry is done as in the example, the column breaking problem will be fixed."kasky":6g5udzq4" said:HELLO how can I fix the column shear force is not provided in the attached project?You do not have permission to view link Log in or register now.
