izmirlimuhendis
If we draw a 175/25 size wall modeled as acceptance as a column, will this cause a change in the calculations or the reinforcement order?
the question is not clearly understood. /175 If you are wondering if there is a difference between defining a vertical element as a wall object and as a column object; If you model it as a 1-panel object and a shell, it will be considered as a wall because it provides 1/7 ratio and the reinforcement arrangement will be accordingly. It behaves like a shell and breaks down to sub-objects and with finite element modeling, load transmission is very smooth. For example, it transmits the moment and axial load to the foundation from many points, which is basically a more positive effect. If you define it with a 2-column object, the center is modeled with a bar. It is equipped with a shear reinforcement arrangement as it provides the ratio of the shear wall. The load bearing system is in the form of a single note bar. Other effects are transferred to this center with a rigid arm. For example, the moment and axial y It transmits the three from a single point, which is basically a more negative effect."izmirlimuhendis":1i0gbvzv" said:If we draw a wall with 175/25 size and modeled as acceptance as a column, will it cause a change in calculations or reinforcement order?
Elements entered with column object in the program are modeled as bars ."sereze":3jkk7cpo" said:I want to model the column as a shell (because one end is on one axis and the other is on the other axis), but I want its reinforcement and verification as a column. Is it possible?
