teknikisler
Can partial beams be made like the K1 and K2 Beams in the above project? Let's say, when it is necessary to define a column for the attic on the last floor on the K5 beam, should the K5 beam be defined in parts? Should the beams be given the same name in beams added end-to-end? When the same name is given, the geometry control does not receive a message in the form of objects with the same name?
