column beam trimming
Hello, There is no such feature as trimming the column with a beam. You can call our Istanbul or Bursa office, explain the situation you want to do, and find a solution with alternative commands. It's easy, good work.
Hi, it is not possible to trim the column with the beam. I can suggest a different way to get the image you posted. Create and place the roof surface with the same slope as your beam at the point you marked. Then trim your column using the "Cut with roof" command. If you do not want to see the roof surface, you can turn off its layer. For detailed information, you can call our Bursa office. Good work...
