Column beam shear safety
I noticed while checking the column beam shear safety in my project after the update, this security check is not performed on the column to which the beam stuck in the beam is attached, I guess it was a problem after the update.
Re: COLUMN BEAM SUTTING SAFETY Now, I have looked again in detail, none of the cantilever and stud beams are checked for column beam shear safety, does anyone have the same problem? When will this problem be fixed?
Re: COLUMN BEAM CUTTING SAFETY In the analysis settings, on the earthquake code page, there is an option to make this control on cantilever and simple beams (it was there before).
