column beam shear safety
bartayd
The result of the analysis does not show an error when getting a report, but in the report, the same column does not pass through the municipality because there is a ticking error on all floors. Even if the report does not give an error, is it necessary to re-analyze and correct all the red ticks in the project?
Hello. Your prediction's errors in column (B). You need to fix it. (It does not write this error in the first place when receiving the report. It should. Although I warned many times, IDE did not add this error as an error message in ideRAPOR.) Ünver ÖZCAN
