Column Beam Rigidified Butt Plate Joint
memorandum07
Greetings, This junction is suitable as long as the columns are on the same axis (alignment), but when the columns are in different alignments, an alternative should be added in the b setting of the forehead plate in the junction. What should be (stub connection) is picture 3 and 4 in the appendix.
Hello there; If you shift the beam by the amount you define with b (move command), the joint will conform to the geometry. Good work.
Hi, if I move the beam with the move command, it straightens one arm. I guess it is not possible to move the beam on both sides with the move command. Or there is a way to move it as a point, I don't know. If you make an example, I will be visually happy. Good work..
