column-beam junction error
Sn new - If you make the concrete C30, - S02 and S03 columns K06 Beam, - S06 Column with K22 beam, - S07 column with K26 beam (B), you don't have any mistakes. Take it easy Unver ÖZCAN
Unver teacher, I have uploaded the architecture. Can you take a look at it as if the columns you have turned are not suitable for architecture?
I made a 40/40 column for the new --S02 and S03 test purposes, both of these columns give (B) error. -- Suggestion: To get rid of this error, you can solve it by removing the columns S02, S03, S06, S07 and replacing the K06 and K12 beams (with shell modeling) by making a curtain. Take it easy, Ünver ÖZCAN
Unver, there is an entrance door under the K12 beam, we can't put a curtain there, I uploaded the architecture at the top, you can see it from there, I can't find any other method.
You can open a doorway on the ground floor by removing the S06-S07 columns (with shell modeling) instead of the K12 beam. (There is a 135 cm curtain on the sides, according to the architecture.
