Column beam joint
Talha Furkan
Hello. I know that I need to connect the beams at the nodal point of the columns, but I could not adjust the offset because I need to place an inclined beam on the inclined axis. I connected the beams not at the nodes of the columns, but at the corner points, will this cause any problems? Thank you for your interest.
"Talha Furkan":31h7u66p" said:
Hello. I know that I need to connect the beams at the nodal point of the columns, but I could not adjust the offset because I need to place an inclined beam on the inclined axis. I connected the beams at the corner points, not at the joints of the columns, will this cause any problems? thank you for the help.
it helps, good luck. ]
