beyazbaret
I'm having trouble securing the column beam junctions shear. Apart from increasing the column dimensions, I try to overcome the problem by offsetting the beams and making the continuous beams different in height. Are there any other solutions than these? Would this be a healthy solution? I made 25 cm wide curtains and it gives ab insecurity in the beams attached to the curtains. I have no chance to make the curtain 30 cm. How can I overcome this problem? Thank you from now
