Column-Beam Joint shear safety
unver
In a project I'm doing: When I click the "Earthquake regulation general report" icon, IRREGULARITY REPORT comes to the screen, no error message appears at the beginning of the report, and when I create a report, there is no warning information as an error message at the beginning of the report. Column-Beam Joint Cutting When I check the canopy, (B) error is seen. SUGGESTION: The builder and controller of the project can skip this error because it does not give a warning. Can't this error message be given at the beginning of reports?
Hello, Mr. Unver, In the column-beam shearing safety report, "Unsafe" is written for the elements that do not provide the column-beam shearing safety... it is also seen as a B warning in the column reinforced concrete as you stated... In one of the old versions of the program, we used to give a warning at the beginning of the report as you mentioned. .. most users reacted so much that; At that time, it was specifically requested not to show the B error at the beginning of the report. Above this, the warning given at the beginning of the report was removed. I don't know if the grounds for refusal are still valid. As I wrote, column-beam cutting safety control is done completely in the program; Elements that do not provide these are shown in the column reinforced concrete and column-beam shear safety report. Good work...
SN Hakan ŞAHİN İdeCAD users may have had such requests in previous versions. Now, if they have such requests, even if a user explains the reason for these requests, provided that it is correct and logical, do not put my request into practice. If there is no correct and logical explanation, I hope you put this control in the new version (7.017).
