Column Beam Joint Shear Safety Problem
Apokalips
Good afternoon, I am having a Column Beam junction security problem in the attached project. I am making changes to the column aspects in terms of architecture. Can I get your suggestions and advice on this issue?
Hello, If you cannot increase the column size related to column beam shear safety, you can increase the bj distance. Check out the document I shared in the attached file.
Hello friends, in a project I'm working on, there is a shear safety problem in the ground and first floors of the column beam connection area in 1 column, I do not have any other columns. Is this a big static problem so what can be done to fix it? I would be glad if you help.
According to the regulations, you should fix this problem. Size the column by downloading and examining the pdf file given above.
Hello, I have read a lot of comments on the forum about this problem, I have made various changes taking into account the solution suggestions, but I still get the same error. Can you help me with this? I am a new graduate and I am trying to learn the IdeCAD program by myself. I am also having a deflection problem in my project, I would appreciate it if you could help with this. Even if I make the aforementioned columns S003 and S005 40/40, change their direction in the direction of the beams, or change the lengths of my beams, the result does not change. The reason I showed it this way was to minimize the visual disturbances in the architectural project.
Hello
"mustafayld":38cl5vwh" said:
Hi, I have read a lot of comments about this problem in the forum, I have made various changes taking into account the solution suggestions, but I still get the same error. Can you help me with this issue? I am also having a deflection problem in my project, I would appreciate it if you could help me in this regard. Even if I make the aforementioned columns S003 and S005 in 40/40, change their direction in the direction of the beams, and change the dimensions of my beams, the result does not change. The reason why I show it this way is to minimize the visual disturbances in the architectural project.
The proposal project is attached. Ünver ÖZCAN
