Column beam joint safety problem
"unver":5wh6h57q" said:
Hello Suggestion is attached to the project Ünver ÖZCAN
hello unver sir, I think you have removed the basement floor rigid sign, I did not see any other changes, is there any other change, I would be grateful if you could inform me.
There is a shift in the columns and beams stuck in the columns with B error, there is a 5 cm enlargement in a column on the lower floor.
