asilturk1981
Can you check if there is a problem in the connections of pillow beams, columns and curtains in the system I created, I have a problem while creating the flooring, when I calculate, the beam connection is made, but in the reinforced concrete-beam-reinforcements section, the reinforcements are not as they should be, do not the pillow beams need to pass through the curtains, for example, the basement floor P179 How should I make the beam connection on the curtain?
