Column beam connection
bartayd
At the column-beam junction shown in the figure, in the left junction, the text remains inside the column, and if the normal junction is formed on the right, is the left junction incorrect?
"bartayd":kmls1owb" said:
At the column-beam junction shown in the figure, if the text remains inside the column in the left junction, is the normal junction formed on the right, is the left junction incorrect? If the beams are also moving, there is no problem in the joint.You can change the object trim method of that beam, regarding the beam text remaining in the column.
