COLUMN AND FOUNDATION STRIKE
OUR DISTINGUISHED FORUM AUTHORIZED ANALYSIS AFTER SELECTION During the hoop diameter ACCORDING in Sonck in COLUMN AND BASIC TIPS, COMPRESSION ZONE ACCORDING in STIRRUP SPACINGS 18CM COMPRESSION REGION 8 CM AS VALUES IN COMES parameter settings minimum OWNER SETTINGS to CHANGE DESPITE STIRRUP AARE VALUE OF 20CM OR 10CM SUCH VALUE CAN NOT RELEVANT INFORMATION VERİRS If your I Şenver .Would be nice if you could describe where the settings are from. THANK YOU IN ADVANCE. GOOD WORK
Hello, Stirrup intervals in the tightening zones are determined automatically according to TDY Article 3.3.4.1. According to this article, for example, for a column with a short side length of 25 cm, the tightening zone and the stirrup spacing is 25/3= 8 cm. The tightening zone is continued at a certain distance in the foundation, according to the same article. The range values given in the parameters are for the compaction region. However, it is not allowed to choose the given value other than the conditions specified in the TDY. The program first selects the values in TDY. If there is something you want to point out other than this answer, please make your question more specific by pointing it out on the project... Good work...
