Column and Beam Stirrup Selection After Analysis
zalman
Hello Friends... In some data entries I have made, I am getting shear capacity error since column and beam stirrup spacings are not selected according to the calculations after the analysis. What is the reason for this?
"zalman":2b79ud5q" said:
Hello Friends... I am getting shear capacity error since some of the data inputs I have made are not selected according to the calculations after the analysis of the column and beam stirrup spacings. What is the reason for this?
Stirrup selection required for reinforcement selection Check the reinforcement selection. If you add a sample project, we can write a clearer answer.
There are 2 different cases for columns 1. For columns, if you make the minimum-maximum stirrup spacing 10-20 instead of 10-10 cm in the column parameters, there will be no problem 2. For beams, the design shear force is higher than the vertical load, the one side is simply supported beams. You can increase the diameter of the beam middle zone stirrup reinforcement by yourself until the beam achieves the shearing capacity of Vr. In this type of beams, automatic selection of stirrups is in our notes.
Thank you Mr. Hakan. Columns are also 10 - 10 The reason we chose it is for complete compaction, but it still crosses this limit. So, I want to make a complete 10, but I intervene later. In the beams, we will do it by increasing one by one. It's not a small problem anymore, I just wondered why it was caused. Good Work Regards...
