Hello --" but to this short column(K22)"" I think you are talking about the KZ22 beam, --the most practical solution is to increase the height (I don't know the architectural project, but there is no such thing as the beam heights of the whole project will be the same.) --KZ23 beam is very The shorter P01 curtain can be combined with the S10 column. (There may be a curtain between the e, f axis.) --avoid short beams --you can solve column (B) errors by pulling the column to the right or left, --Consider the stair load, Take it easy Ünver ÖZCAN
