After importing dwg or dxf, you can use the "Tools/2D architectural project read" command, for an explanation of the command, see the F1 help file."MKY60":10hdbuh9" said:good day, I would appreciate it if you could post a link on how to define columns and beams after loading the architectural project from import or if there is an idecadin training video on this topic
The drawing you import for the 2D Architectural project must be divided into layers. For example, in the architectural project, you can use this command if the axis lines are on its own layer and the lines showing the column are on its own layer. Otherwise, see my other management. Ax, column, If you don't know how to draw beams etc., you may have difficulties. To learn the program, watch the training videos at the following link:"MKY60":1hzaexat" said:hakan bey I clicked on the 2d architectural project arrow and wanted to convert it to a column. After clicking on the column layer, all the drawings in the project except the column disappeared, but when I click on the column, I cannot define the column because I have just started the program I don't know where I went wrong
