Coinciding with the junction of the thrust region with the beam in the column
mustafaureyen
HELLO, EASY TO EVERYONE. TWO BEAMERS ARE CONNECTED AT DIFFERENT LEVELS IN MY STAIR COLUMN. THE PROGRAM GIVES SUCH DETAILS, RESULTING FROM COLUMN LONGITUDINAL REINFORCEMENT AT THE JOINT OF COLUMN-BEAM. CAN I GET YOUR COMMENTS? THANKS...
Re: COMES TO THE JOIN OF THE OVERLAP ZONE ON THE COLUMN Hello, TBDY2018 figure 7.3 is a suitable detail, Ünver ÖZCAN
Re: COMBINATION OF THE OVERLAP AREA ON THE COLUMN WITH THE BEAM The detail seems to be appropriate. In any case, the moment that will appear on that console will be very small compared to the frame moment. However, if I were you, I would talk to the architect and intervene in the project. In those last two axles, your frame is not complete because of the stairs and floor space. It's a much more important issue than the detail you asked, in my opinion.
