Coating to cover the scissors
masmay
I WANT TO COVER THE 3 FACADES I DRAWN LINES IN THE PICTURE TO CLOSE THE SCISSORS. I SHOULD RECEIVE PERFECT REPORTS AS A RESULT OF THE ANALYSIS OF THIS COATING. I HAVE TO SUBMIT THE REPORTS PERFECTLY, BECAUSE IT IS A DESIGN PREPARED WITHIN THE SCOPE OF TENDER TO THE UNIVERSITY. WHAT SHOULD I DO. I WOULD LOVE TO HELP
Re: COATING PROBLEM Hello; First of all, with the purlin command, you can create a surface on which you can properly mount the cladding at column alignments. Then, if you can create 2 purlins at the scissor level using the single purlin command, you can insert a coating between the single purlins with the inter-element coating command. During single purlin modeling on the scissors, you can use the create special snapping points command on the object, for example, after selecting the scissor upper heading and right-clicking, to enter the purlin from the appropriate points. If you have a problem, you will be helped if you send your project to the steel support mail. Good work.
Nurgul, first of all, thank you very much. There is something I missed in my post. I want to cover up from where I drew the red line, including the scissors. My floor height is 4.70 m. I want 3 meters of clearance below. Even my current drawing cannot be analyzed. the program closes itself. geometric controls do not appear to be a problem.
Hello there ; We need your project so that we can identify the reasons for the program shutdown during the analysis. I will ask you to send it. Good work.
If there is project data, we can comment. But you can easily make lovers in columns with the purlin edit command. Adjust the distance of the lover at the bottom and do what Nurgul says for single lovers. Also, you have connected the columns with beams in the direction of the truss.
THANK YOU FOR YOUR HELP, I HAVE PARTIALLY SOLVE THE LOVE PROBLEM. SARIDURMUŞ, YOU ARE DEFINITELY RIGHT I CAN REMOVE THEM..
