CLOSING PROBLEM
The file structure seems to be corrupted in the project you added. If "Backup while saving (*.bak)" option is checked in the general settings dialog, backup files with *bak extension are created under the same folder as your project. In the load project dialog, select the file type *.bak and try to open these files. Good work
