kadirbulut2012
I want to define a cassette for the attached project, but somehow I couldn't. Typical beam determination part turned into a complete puzzle/maze. If I ensure the continuity of one, on the other hand, I cannot.
thank you for your answer, the thickness of such things like plaque etc. is random I just tried to explain that I couldn't choose the typical beams. I haven't started beam-column-floor section and dimensioning yet. Because the project was normally a plate, a few changes were requested later, the column was removed, added, etc. I got errors while I was converting it to a test cassette and positioning the typical beams. " probably like beam discontinuity.." Regards, thanks again cures."2m project":abstwanv" said:Hi; You can place the cassette as you do, however, it is useful to place your cassette molds optimally according to the mold sizes you have, such as 1/1 - 1/2 when placing the cassette. I am sharing the drawing I prepared as a suggestion in the attachment. It will be a more suitable solution if you determine the dimensions of the main beams inside and around it according to the placement and height of the cassette molds. Also, I think 20cm plate thickness is too much for cassette flooring. Regards.
Dear nyılmaz, I applied it as you did in the picture, but I get the same error. Don't you get an error or are our techniques different. Which elements did you choose to direct the tapes in this way?"NYILMAZ":abstwanv" said:This is mine too. It seems like I would do it. I would choose typical beams as in the picture. NY
yes I'm doing exactly that. It's the first time I'm working on tape-rib, but this is I'm probably getting a typical beam continuity error in the geometry check. Is this a negligible error?"NYILMAZ":35b33d0g" said:Do you select typical beams with the define typical beam command? This way they are defined. It does not give insufficient typical beam error. Continuity is not always something that can be fixed. Continuity may not coincide depending on the placement of beams. When I do it myself, obviously continuity I tried to create it but I didn't look at the geometry control. I closed the project without saving it too. So I couldn't do it again. Because I used perpendicular references there, etc. I didn't mind doing it again. The truth is![]()
You can ignore it if you do it consciously."kadirbulut2012":tlnqkdvx" said:yes i am doing exactly this first time i am not working cassette-rib but this is probably typical i get beam continuity error in geometry check.is this a negligible error? i did continuity with a solution close to what you did but continuity error
There are two classes in the geometry control. Error or warning. The message in the screenshot you attached is warning, error not . The program says "there is such a case, please check it out". If the data entry you entered is suitable for your purpose, and the data entries suggested to you seem appropriate, you can ignore this warning."kadirbulut2012":9mo5q1el" said:I feel like I will encounter big errors in the outputs I will receive.
Although I have used the error/warning distinction all this time or because I have always perceived it as an "error", I did not pay attention. thank you."HakanŞahin":205c8ji5" said:There are two classes in geometry control. Error or warning. The message in the screenshot you attached is warning, not error . The program says "review there is such a case". If the data entry you entered is suitable for your purpose, and the suggested data entries seem appropriate, you may ignore this warning."kadirbulut2012":205c8ji5" said:I seem to encounter big errors in the outputs I will receive.
