circular linear load
201968
Good evening; I want to enter a linear load (parapet/railing load) on the slab end that is circular in the attached photo. How can I enter the circular linear load? It can be defined as a straight line in the program.
Re: CIRCULAR LINEAR LOAD
"201968":3d3jcu3y" said:
Good evening; I want to enter a linear load (parapet/railing load) on the circular slab end in the attached photo. How can I enter a circular linear load? It can be defined as a line.
Hello, You can define the load on the curvilinear edge of the slab with the -Arc wall command, -You can define the point slab load in small intervals with the command, you can define the linear slab load piece by piece.
Re: CIRCULAR LINEAR LOAD Will it be healthy to calculate the motif beam load hanging from the parapet/railing and slab end and enter it as a spring wall or linear-point load at the end? (motif/parapet detail will be corrected manually)
"201968":2bsok4ze" said:
Is it healthy to calculate the motif beam load hanging from the parapet/railing and slab end and enter it as a spring wall or linear-point load at the end? ( motif/parapet detail will be corrected by hand)
The load of motif beams can be entered as point, linear floor load and wall load.Your similar question was answered in the following thread before.
Good work
