murat mungan
THERE IS NO CHANGE IN THE R COEFFICIENTS ENTERED AND SELECTED IN THE PROGRAM. BEST REGARDS
"murat mungan":2nuu4v2u" said:THERE IS NO CHANGE IN THE R COEFFICIENTS ENTERED AND SELECTED IN THE PROGRAM WHY IS THE CAUSE OF THIS, WHY DOES THE PROGRAM COEFFICIENT DEFINE THE NUMBER OF R COEFFICIENTS REQUIRED. ... We give the initial R coefficient value in the project general settings.After the analysis, the program can automatically reduce the R coefficient by multiplying the R coefficient by 1.25cmmin according to the 1. TDY item 2.3.2.3 (if it needs to be reduced according to your system) 2. If your building has a panel outside the rigid basement, The suitability of the R coefficient you entered is automatically checked during the report phase. The program will give you the alphas rate according to the R coefficient value you entered. According to the warning, you determine the new R coefficient according to the principles in item 2.5.2. Then you enter this value in the project settings and analyze again. If we look at the report you added , R=8 was taken in the system and item 1 was not applied (not required). you need to base on the warnings given by gram. If there is no warning, it is not necessary.
