Cassette-rib openings reinforcement overlap lengths
In the cassette expansions I have attached, the longitudinal reinforcements are placed every 12 m and are cut and added in each slab instead of overlapping. Is there a possibility to edit the drawing in the program to prevent loss that will occur in this case? Does the 'combine shorter reinforcements: 1200cm' option in the general reinforced concrete settings work, so even though it is selected, I cannot get the drawing I want.
Hello, the possibility you asked for rib/cassette expansions is not available in the program. This possibility applies to beams.
