Cassette flooring recommendations
...fatih...
Hello my dear colleagues. I will draw cassette flooring because my customer insists on hollow floor slabs (he does not want teeth), but I need your advice as I have no previous experience. Thank you in advance for reviewing and commenting on the project. Good work -I added 3 curtains to the system to stay on the safe side. -Additionally, a sub-basement curtain will be defined on the basement floor. - Foam filling will be used in the application, although I do not want it.
Hi My suggestions --Check the coordinates of the structure, --1. Uncheck basement rigidity, --Make stair bracing, --Rx=Ry=7, select A15, --Remove wall loads on the top floor, --Analysis settings-load security-Tick TS500, TS498, --Near the ladder put a beam around the gap, --Make the cassette 70x70. --Finish the calculation by making all the finite elements 0.25 m in the final calculation. If the relative floor offset is large, you add curtains. Unver ÖZCAN
"unver":1x06e37c" said:
Hi My Suggestions --Check the coordinates of the building, --1 remove the first basement floor rigidity tick, --Make the stair bracing, --Rx=Ry=7, Select A15, --Remove wall loads on the top floor, --Analysis settings-load security-Tick TS500, TS498, --Put a beam around the gap next to the ladder, --Make the cassette 70x70. --In the last calculation, all finite elements are 0, Finish the calculation by making 25 m. If the relative floor drift is large, you can add a curtain Ünver ÖZCAN
Thank you, Ünver
