Are cassette tiling the same thing as bidirectional gear laying? Are the following definitions correct? WDDD: Teeth spacing max. 70 cm. Tooth width min. 10 cm. Cassette Flooring: Instead of teeth, there is a secondary beam. Minimum secondary beam width 20 cm. Beam spacing is free. There is a system that I need to make a hollow block due to closed protrusions and wide openings. H>17.50. Which system should I choose? What are the pros and cons? In idecad, is the calculation of the secondary beam and the calculation of the teeth done in the same way?
