Cassette flooring 20cm below, 32cm above How to enter
"unver":2eqcu4qb" said:
I wonder what kind of project this was?
I think you misunderstood Mr. Üncer. What he is talking about is that the rib beam is 20 cm on the bottom and 32 cm on the top. Of course, the size changes. You cannot give the rib width as trapezoidal in ideCAD. You will take the smallest section, 20 cm. You can either correct your section drawings manually or give a typical section.
