- I am referencing the same location on all cassette tiles on the floor. i choose as reference . however this error occurs . -I have already defined a typical beam.(Is there a place I have done wrong or missing. I do not understand, sorry) -If I define a beam at the end of the console floor, won't there be a plus load? Isn't the floor edge healthier? just the idea, of course you know better.) -If the TS500 E does not fit, why does the program not give a warning? -What do you mean by secondary beam? Should I go back with the normal beam? Or is there a separate command? thank you ."Levent Özpak":2tzlfpuf" said:Hi, -You can reference the same beam or line when creating all cassette floor teeth on the floor (For example, you can define a line from the bottom edge of the project for the teeth in the x direction, for the teeth in the Y direction refer to the beam K21 with its name on the ground floor. You can select beams.) You can define the calculation beams with the "Determine typical beam" command. -You can model beams instead of the floor edge on the outermost edge of the console floors. -It is appropriate that the tooth spacing of the cassette floor does not exceed 70 cm according to TS 500.You do not have permission to view link Log in or register now.-It is recommended to use secondary beams instead of slab edge for cassette slab spacesYou do not have permission to view link Log in or register now.Good work
For all floors, the bottom of the project for the teeth in the x direction, to avoid large tooth gaps you can define a line from the edge, choose the reference beam K21 with its name on the ground floor for the teeth in the Y direction."3428":3mnendg2" said:- I refer to the same location on all cassette floors on the floor. I choose the elevator curtain as reference. However, this error occurs.
-isn't there a plus load if I define a beam at the end of the console slab. Isn't the slab edge healthier. just the idea, you know better.)[/quote ] This suggestion has been made so that the teeth do not work as a console. IfIt is among our request notes to give a warning. What do you mean by-TS500 E does not fit, why does the program not give a warning.Yes, it is suggested to define a normal beam.It is expressed as a secondary beam as the beam will be supported on other beams.secondary beam. Shall I return with normal beam. Or a command separately Thank you .
"Levent Özpak":1x99sf26" said:You can define a line from the bottom edge of the project for the teeth in the x direction for all slabs to avoid large tooth gaps, and for the teeth in the Y direction, you can choose the reference beam K21 with its name on the ground floor. Wouldn't there be a plus load if I define a"3428":1x99sf26" said:- I am referencing the same place on all cassette tiles on the floor. I choose the elevator curtain as a reference. however this error occurs.This suggestion has been made to prevent the teeth from working as a console. You can check the referenced link on this topic.-beam at the end of the console slab. Isn't the floor edge healthier? just an idea, of course you know better.)You do not have permission to view link Log in or register now.Thank you very much .-TS500 Why doesn't the program give a warning if it doesn't fit .[/quote ] It is among our request notes to give a warning. It's okay if you don't include it in your notes![]()
Yes, it is suggested to define normal beam. Since the beam will be supported by other beams, it is expressed as a secondary beam.What do you mean by the secondary beam? Should I go back with the normal beam? Or is there a separate command? thank you .
