Cannot Create Raft Tile Network Error
celikbey
Hello. In the attached system, when the raft is 100 cm from the outer contour, it gives an error "UNABLE TO CREATE A NETWORK FOR 2nd BODRUM" in "RD07", it does not give an error when I make 105. I want to try 100 because the stress value at 105 is too high. By the way, I searched the forum for the issue. There is a related, similar topic, but it doesn't quite match my problem.
Re: Cannot Create Raft Laying Network Error??? Hello, you can analyze using the rate of 0.35 h when Direct Connection Option is selected or Enlarge Connection Area option as the Raft basic connection method in Analysis settings. Unable to create finite element mesh of raft foundation using 0.5h ratio.
Re: Unable to Create Raft Tile Network Error??? Thank you. As you say problem solved. But what is the reason for this error? Is it a software problem?
Re: Cannot Create Raft Floor Network Error???
"celikbey":11qfi35d" said:
Thank you. The problem is solved as you said. But what is the reason for this error? Is it a software problem?
I'm forwarding your project to the software department for review.There is no problem with your data entry, it seems like a software problem.
