mühendis34
friends, like in some other static programs, can we directly transfer the architecture to static and handle the axis places or other operations... Just like in sta4....
"engineer34":2qa7clxs" said:how can we do this... I want to benefit from your experience guys.. I started drawing a new project...thanks in advance...[/ quote] Hello, You can convert the imported 2D drawing file to axle, column, curtain, beam objects by using Tools/2b read architectural project command.
The conversion process is also done correctly."engineer34":3ji82l55" said:there is no negative error direction in the system..
You can open the project you made in ideCAD Architecture directly in ideCAD Static. The whole project will appear. 2D architectural project with dwg export You don't need to use read."sefaaydinn":2jgbmsvi" said:When I make a 2d architectural project arrow in the project I loaded from Ide architecture, do I need to convert the columns, beams, or axes because I transfer them from the architecture? dedgmds says "There are blocks in the project, blow up the blocks you want to use". In this case, how should I go about it
