Can we assign moment?
insburak355
GOOD DAY I HAVE A STEEL CONSTRUCTION PROJECT I HAVE COLUMNS CONSISTING OF PROFILES (CONNECTED TO THE SINGLE FOUNDATION WITH ANCHORAGES) I WILL BUILD SINGLE FOUNDATION BELOW. I THINK I CAN AFFECT THE POINT LOAD FROM THE SINGLE BASE, I THINK, I CAN AFFECT THE POINT LOAD FROM THE COLUMN IN THE PROGRAM, BUT HOW DO I TRANSFER THE MOMENTS FROM THE SINGLE BASE TO THE SINGLE BASE? THANKS
FIRST THANK YOU, BUT MY COLUMNS ARE STEEL NOT REINFORCED CONCRETE. SO I HAVE NO REINFORCED CONCRETE COLUMNS THAT I CAN AFFECT MOMENT OR POINT LOAD. AS I SAID, STEEL BUILDING COLUMNS WILL BE BUILT IN I PROFILE CELETEMANKELEKONUK. SO SHOULD I ATTACH THE LOAD AND THE MOMENT DIRECTLY TO THE FOUNDATION? IS THIS POSSIBLE ?
The foundation cannot be solved without the superstructure in the program. If your goal is the basic solution, you can model by entering a reinforced concrete column instead of a steel column.
