Re: Console Length If possible, do not make all the columns in the same direction. If you design the rib beams as I said, there is no need to put a column at the point you say. Instead, if it will not cause a problem on the façade, it would be a more practical solution to make K12, 23, 24 beams as horizontal beams and continue and connect the K12 beam to K19. Even if you put a column at the point you have mentioned, this time the cantilever beam situation will occur from the column that does not continue, which is not a very preferred situation.
