B bsrdsbdk New Member Feb 17, 2021 #1 Hello, in the plate system I solved with 25*50 beams, can I solve only one beam in 50*30 size?
U unver New Member Feb 17, 2021 #2 Re: BEAM DIMENSIONS Hello "bsrdsbdk":19fnqgyk" said: Can I solve only one beam in 50*30 size in the plate system I solved with 25*50 beams? Click to expand... If your floor thickness is 10 cm, 3 *10=30 cm height can be solved Unver ÖZCAN
gulayakyol5 New Member Mar 2, 2021 #4 hello, when you define the beams as 25 * 50, it says insufficient cross section, can you help?
