F felamurr New Member Aug 23, 2013 #1 Since there was no error in the junction of K62-K63 beams in the S34 column, after sliding the K62 beam 7 cm up, the DM10 balcony deflection limit was exceeded. I couldn't understand the reason. I would be glad if you help
L Levent Özpak New Member Aug 23, 2013 #2 If you attach the project file, we can check that there is no problem with data entry.
