After replying to you, I realized that there are problems with my computer. I'm trying to fix it. Please ignore my last posts. Ünver ÖZCAN"netdelisi":28w4a8ba" said:I didn't get a solution even though I entered again, how did you solve it ünver bey
You can control your building loads and distribute your loads by adding additional columns"Nurullah Yurdigül":j9ysmt3g" said:there is a stapling error in the raft foundation. What solution would you suggest other than enlarging the cross section and using a punching reinforcement.
"cvlngnr":1jpdssm1" said:Hi, I am getting a stapling error on the elevator curtain in my project. I would appreciate if you could help.You do not have permission to view link Log in or register now.
hello, when I fixed the node as you said, the problem was solved. Thank you for your interest. I wish you good work."oguzcan":180xdo92" said:Hello; I reviewed your project. Since beams are attached to this elevator curtain, stapling control should not be done. However, as I am trying to show in the picture below, a small portion appears to be protruding from the curtain beam connection. If you define this curtain at the end of the beam, as in the P06 curtain-beam connection, your problem will be solved. Best regards..."cvlngnr":180xdo92" said:Hi, I'm getting a stapling error on the elevator curtain in my project. I'll be happy if you can help me.You do not have permission to view link Log in or register now.
hello. As I said before, what solution would you suggest without using a cross section enlargement or punching equipment. I am working on a sample project. A project that has been implemented .There is no stapling error in his project . He did not use stapling equipment . Even though we use the same sections , I have that problem . Thank you ."unver":1z7pr9zk" said:Hi Raft tile stapling security is not providedYou do not have permission to view link Log in or register now.Please review Ünver ÖZCAN
