Can't I select a beam that is not a slab neighbor as a reference beam?
mkrts88
The model is not finished yet. It gives an error when I analyze it because I tried something on the rib beams, I think when I returned the rib beam orientation to normal, it did not fail, this state gives an error, not in all rib beams, but in some ongoing slabs, can I not select the beam that is not a slab neighbor as a reference beam? I guess I can't choose it, the model gives an error too
Re: Can't we select the beam that is not a slab neighbor as a reference beam
"mkrts88":5j5ocrjm" said:
model is not finished yet. It gives an error when analyzing, I guess because I tried something on rib beams, it did not fail when I returned the rib beam orientation to normal it gives an error
Hello, I opened the project you added. I did the analysis, the analysis ended without any errors. There is an incorrect column-beam intersection warning in the geometry control. You can also look at it.
not on all rib beams but in some continuation slabs, can't I select the beam that is not adjacent to the floor as the reference beam? I guess I can't select it, and the model gives an error
You can choose the beam you want as a reference. There are no restrictions.
