Can't get rid of errors in attached project
mühendis55
good day, there are errors in my attached project beam n max, column pursanaj etc. c30 used. Errors may occur due to data entry. I want your help. Also, I did not put a ladder in the building, I tried the solution many times, but I could not reach the result. Please do not install it on the stairs. Since a shop will be built on the front of the building in the Y direction, the column has been avoided. There is no problem with those beams. url]
