Hello, do not fix columns, beams, curtains, foundations, etc. with DS. --Increase the number of modes, --Click on the D1-D2-D3-D4-D5 slabs on the ground floor and select the option to create a rigid diaphragm and calculate the calculation. when you do it, it gives the same error only in the lower left block. My suggestions; --Separate the blocks, calculate one by one, the calculation is easier and you won't make modeling mistakes, --make a semi-rigid solution, --You can reduce the live loads on the attic floor, you can remove the wall loads, --If you are going to make the stairs a rigid solution, give the loads, --Remove the left lower block column DS It saves when we calculate. The suggestion is attached. Ünver ÖZCAN
Ünver, thank you very much for taking the time to help. It is a very important project for me and it is time-consuming. I try again by making your suggestions, but there is another small building independent of this building and I get many errors in the analysis of this building. I think I am making a mistake in the data entry. I don't understand. I'm sharing the link. I would appreciate it if you give me an idea. Since the roof will be steel, there is no upper floor flooring.
Mr. Ünver, a ladder was added to the project we discussed, but I couldn't figure out how to model it. I can't enter the floor landing as a floor. It creates the route object in a different place. The ladder rotates 2 turns, I circled it. When I tiled, the connections seemed to be troublesome.
