Ünver Bey, I checked my project, I already entered the ground class as ZE. I marked the 3rd floor engine room, bks was 7 and I tried to reduce the loads and I made c30 and made a raft 60 cm ampatmans rear corner as it will be but I still can't get results. If I put a curtain, where should I put it, I tried it with curtains, now I'm confusing what I know, I was thinking a lot. There is also a post circulating in the forum, do dd1 and save, then dd2, save and analyze. I took the values from afadd and entered them manually. I did this as well, but where am I going wrong?"unver":1tda1wa0" said:Hi My Suggestions: --In this case, the ground bearing capacity is 25.7 t/m2, check the ground carrying capacity quite a bit, Is the value you used in the calculation 1.4 divided floor bearing capacity? --You put the S23 column on the door, correct the static modeling, --Enlarge the raft foundation from both sides, if not, increase the reinforcement, if not, increase the thickness, -Mark the 3rd floor as the elevator engine room, -- Reduce the floor loads of the 2nd-3rd floor, remove the wall loads, --You can make the concrete C30, --Fix the B errors, --If it still does not save after doing the above items, add CURTAIN, (group around the stairs and elevator Define it by doing it) --You can support and add the stairs last. Ünver ÖZCAN
Make this suggestion. Share it, if necessary, I will correct it. Ünver ÖZCAN"unver":vvyrm6a9" said:--If it still does not save after doing the above items, add CURTAIN, (define by grouping around the stairs and the elevator)
suggestion, thank you for your effort. I finally saw this, but I want to share the points I don't understand - the coordinate values in the project I uploaded are different and the dd2 column is 0 - ground bearing capacity is 40, my ground bearing capacity value is 2.57 kg/cm2 -I can't go to the road front in my parcel of adjacent corner, the friend in the municipality did not allow it -there is a transition from under the stairs to the back where the p07 curtain is"unver":2nuelwql" said:Hello Balanced suggestion project attached. When my version was V10.08, I installed it with V8.62. Ünver ÖZCANYou do not have permission to view link Log in or register now.
