uğur oflaz
"1. Can't curtains be modeled as shells in performance analysis? If they can be modeled, curtains do not appear in the building performance section of the performance analysis report. However, reinforcement curtains appear as the results of barme. I would appreciate it if you could explain this situation. I would appreciate it if you could explain this situation. 2-Although I said "assign" by default in the bide display configuration, on every floor of the building. It gives a separate image shape. I can't do it. 3- As a result of the structure performance analysis, although there is a type cut on the curtains, it does not appear in the crisp element list in the building performance table. What is the reason. Greetings.
