Re: BEAM WALL LOADS Hello As there are 15 cm brick walls on the beams in the project, the program first takes the load of the brick walls. Switch from the formwork plan to the architectural mode and brick walls will appear. From here, you can delete the wall on the beam and enter the desired numerical value from the beam settings on the beam you deleted. Unver ÖZCAN
