Hi; You can perform linear analysis in the Time Domain of the program. "Time History Analysis"[/b in the Structure tree You can define the acceleration records by using the "Time History Functions" section under the ] section. A new time history area can also be created from the "Time History States" section. If you define 11 sets of acceleration records (11X and 11Y), " under "Analysis" You can scale your acceleration records using the "Ground Motion Scaling" command. Apart from that, described in TBDY Section 4.8.3 and detailed in APPENDIX 4B.3. "Earthquake Calculation with Mode Addition Method in Time History" is also available in the program. To use this opportunity, after defining the acceleration records as I explained above, "Analysis"[/ Under the u] menu, there is the "Earthquake ground movements" section. You can save earthquake acceleration records in a scaled format. "Analysis Settings" also includes the earthquake load calculation method "Mode collection method in time history"[/ If you select u], you can perform operations.
