Building height class settings
berKA
For idestatic V10. I want to solve only continuous foundation for hangar type building in the program. I define short columns to be able to input loads. As a result, the program takes BYS as 8. But my building should be BKS 7. When I increase the height of the columns, this time I get an error about the relative floor offset in the reports. How do I overcome this problem. Thanks.
"berKA":2004aqpj" said:
For Idestatic V10. I want to solve only continuous foundation for hangar type building in the program. I define short columns to be able to input loads. So the program takes BYS 8. But my building should be BKS 7. When I increase it, this time I get an error about the relative floor drift in the reports. How can I overcome this problem. Thank you.
The building height class depends on the building height. If your aim is only the basic solution and if the building height class is BYS=7, the Floor height will be BYS=7. You can arrange it in such a way that you can give negative elevation to the columns you define in order to enter the load.
"berKA":29uhb79m" said:
For Idestatic V10. I want to solve only continuous foundation for hangar type building in the program. I define short columns to be able to input loads. So the program takes BYS 8. But my building must be BKS 7. When I increase it, this time I get an error about the relative floor drift in the reports. How can I overcome this problem. Thank you.
