Building Entrance stairs and disabled elevator
mkrts88
I can't define the entrance to the building, I examined the topics about how it was built, but I couldn't do it, the elevations do not come out as I calculated, I thought I should think of the staircase as an inclined floor, although one end of it presses on the curtain and the other end on the beam, it sees it as a console floor as far as I understand, I miss a few tricks
Hello. The slab you will give as inclined; Define the edge of the curtain at floor level, with the beam edge command to the edges of the beams K18-K21, enter the slab, give slope, (select no) change the elevation of the curtain. Take it easy Unver ÖZCAN
Unver, I do as you say, but it does not work, it takes a very absurd form, I wonder at what time of the day we can connect with teamviewer. Or can we? end level = start level - 125 cm, but it doesn't work. I'm also trying different + - ...
Hello. The red lines that you did not define the slab edge to the right and left of the sloping slab. After the slab is marked, give the direction of the sign downwards with the mouse, then enter the slab slope, It is in the last pictures I put. Unver ÖZCAN
