BROKEN AXLES
cihanonarici
Is it possible to define a broken axle in ideStatik or ideMimar? When we say project arrow, the program cannot turn the broken polygons into an axis. Respects.
"cihanonarici":724j23bp" said:
Is it possible to define broken axis in ideStatik or ideMimar? When we say project arrow, the program cannot convert polygons defined as broken to axis, if there is no such support, is it possible to integrate it? Regards.
Broken axes can be created by using horizontal, vertical and inclined axes together in the following program. In the attached project, the C axis was drawn this way. To draw the axis in this way, draw 2 parallel axes from the nodal points of columns S7 and S8. Then, the joint points of these two columns 1. Select the perpendicular axis and click the object properties command. On the Label settings tab, uncheck the right label line. On the General Settings tab, uncheck the -Draw in-contour lines- line. In the right delta line, type -300 cm. 2. Select the perpendicular axis and click the object properties command On the Label settings tab, uncheck the left label line. In the General Settings tab, in-contour lines Uncheck the data line. In the left delta line, write -300 cm. Select the tilted axis and click the entity properties command. On the Label settings tab, uncheck both the left and right label lines. In the general settings tab, write -300 cm in the -left and right delta- lines. Give these three axles the same name. The possibility of drawing broken axles as a single axle is on our wish list. Good work
