Hello, Structure - basic interactive solution selected... However, some foundations seem not to fit on the columns. Check the attached picture, you can see how it can detect the relevant foundations. (Choose the deformation image in vertical loading ) For example, TK90 beam is defined from the top, it is entered by clicking outside the column. Similarly, ST34 etc. P03 element is defined as column element. The continuous foundations you enter under the column are unaware of this column, they just connect to each other. In this way, you need to enter the element as a panel so that you can make a continuous foundation intersection When defining a continuous basis, you should define the nodes so that they fall on the top of the column.
