Hello... The geometry of your building is very smooth. First of all, I recommend that you do not use concrete below c30/37 in such a structure. If your beam spans are too large and the studs are overlapping, if you cannot increase the height of the beams in these spans, it will be in your best interest to increase the width. You may not want to expand the curtains as 25, but your beams can overflow from one side without making the curtain larger. It is normal to have these strains if the horizontal loads on the building are a bit high. The beams between the shears in the x direction running through the core region are like tie beams. This type of beams are very difficult without shearing on the axial upper floors in the basement floors. My advice is to enlarge the cross sections of them. As I said, if you cannot increase the height, you will see that if you increase the width, it will be enough. Good work...
